Hey, Happy July 4th!
Today I am planning to track down an oil leak. Is it the rear seal, or the drain plug?????
It is time to find out. The only way to do this is to clean off the bottom of the engine, start it up, climb under and wait for a drip:)
The truck has been parked outside for about 10 months, so I am not excited about bringing it into my clean garage:)
I have been under the passenger side of the truck for about 25 min. now, and there are no drips. It is idling in the garage, i'll check it again in a few.
Obviously, it does not leak much if it's not under a load.
Anyone know if the engine should idle at 1100 rpm? Off the top of my head, I am guessing it should be 900. Should I look for problems?
veesix
NF Mod/Nissan Master Tech
Rear engine leaks will generally leak more when driving as the oil is pushed toward the rear of the engine.
As far as the idle, should be 800 +/- 50 RPM for MT; 700 +/- 50 RPM for AT models (in "D"). There is an adjustment screw for the idle. Also check the ignition timing: 12 +/- 2 degrees BTDC and any obvious problems, like leaking vacuum hoses, etc.
Well, it idled for a good amount of time.
No leak from the drain plug.
Very very slight drip from the rear seal area.
Stronger leak from the transmission case; from behind a rubber gasket, where the clutch piston works that lever (sticks out of rectangular hole in case.)
I was wondering if the slight leak from back of the engine, could be the same leak as the transmission leak.
Possible.....as the oil leaks from the rear main seal, it tends to get whipped around by the flywheel and thrown against the inside of the bellhousing. Be it the rear main seal or a front trans seal, either case would require removal of the trans. If going that far, it would be a good time to replace the clutch assy.
