my old 88 SE V6 (VG30) has had a seized 'fill plug' on the rear end since I've had the truck. I've tried heating and cooling it, PB blaster, hammers, you name it and nothing has worked so far to remove it. It's rounded out in the inside (where you'd use your ratchet to get it turn it loose) and I'm assuming the previous owner probably used an air wrench to put it back after a gear oil change but I have no idea. It was rounded when I first looked under there a couple years ago.
ANYWAY, while under there taking a look at it, I noticed a little fitting thing on the differential housing itself, on top, on the driver's side....it has a little metal cover that comes off but has a spring and clear plastic disk inside of it. It looks like the fitting on the diff housing that this thing covers, is open and goes down into the differential housing but I couldn't get my head up high enough to look into it.
Anyone know what this is? I can't get the fill plug out and the truck has 210K on it so who knows how long that gear oil has been in the rear end. I'm debating on getting another rear end or figuring out another way to get that plug out. I could add oil thru that little fitting on top but would have no way to know what the level is.
No diff housing cover or bolts or other access into the differential.
Thanks guys any help appreciated!
cheers:givebeer:
also forgot to add: 2WD, 5-speed
cheers:givebeer:
