so you don't break your clips taking it off..
once you have every screw off of it from the outside... speakers.. armrest (the armrest always has a screw.. that's what mainly hold the doorpanel tight against the door)... anything else that has a screw from the outside of the door panel..
then take a flathead screwdriver and work your way around the panel finding each clip and popping it out one by one. if you're nice enough, you don't break anything, but it's liekly you will break a couple so don't freak, the panel usually still hold good enough until you can go get a pack of clips from somewhere.
then like he said, it moves up and off the window sill.
but before you yank, like he also said, you have to disconnect the powerwindows, locks... anything else that's attached to the panel.
take your time here.. ELECTRICAL CONNECTORS ALWAYS HAVE A WAY OF COMING OFF. don't just get immpatient and bust it off to where it's just connected later but without a lock.
the next owner will be grateful that road vibrations hadn't eventually loosened the connections.
reverse order for installing.
fin.
