Cabin air is blowing cold regardless of A/C heat setting.
Remaining A/C functions seems to be working but I need to do the diagnostic test to be certain.
My 87 Maxima Service Manual indicates there is a 'diagnostic test mode' that I start by pushing a recessed switch on the A/C control box. Test results (fail or pass) are indicated on some indicator lights. On which unit are those indicator lights located? Are these test results lights the indicators on the A/C control panel?
Is the valve that allows water to enter the heater core called a 'Water Cock Solenoid Valve'? Is that valve located in the engine compartment at the firewall or inside the cab? Is this a vacuum or electrically controlled valve?
I am reading and rereading the Factory Service Manual.
Thanks for any help. Dave_ss
