hey so i did an engine swap taking a 88 pathfinder engine and put it in my 87 kingcab. hooked it all up and it ran fine for three days around the yard. took out on the road once and it didn't feel right so checked some stuff over. hooked the injector wires back up and then fired it up and it was running fine for 30 seconds and then died and hasn't started since. have lots of spark. engine has lots of compression and changed the upper half of the throttle body and everything on it. tons of fuel coming out of fuel filter but nothing through either set of injectors that i've tried. will run if i keep pouring fuel down through the throttle body by hand. currently changin egr since it was clogged up but i still don't think it will work. any help with this is greatly appreciated. read something about accelerator pump could be toast but i've looked everywhere for it and i don't think this engine has one!
