Hello,
New member here and stuck on a CV install (driver's side) for an '85 HB 4X4 with auto hubs. Hoping there's a Nissan tech guru or shade-tree mechanic here that's done this install and can lend advice.
Problem: Can't get the snap-ring to seat in the channel on the driveaxle spline. Honestly I've done dozens of CV replacements but have never had an issue like this. This design is unfamiliar to me.
Pics...
This is the little beast, it's a friend's truck.
Driver's side hub. This is where the problem lies. The slot on the spline is exposed in this pic... that's about as far as I can pull it through. It's not far enough to engage the snap ring and lock everything into place unfortunately. When I removed the old CV the spline seemed to be pressed into the hub but there's no way I know of to press the new one back in. I'm about 1MM shy! Grrrrr
This is what it looks like with the hardware in place. Just need another millimeter and that ring should snap in.
We tried using a socket that contacts the snap ring... tapping and hammering with the BFH was fruitless. Every time we struck the socket, the driveaxle recoiled, even with a big dude gripping the axle shaft.
So..... what's the trick? Special tool that will draw the driveaxle spline further into the hub? I really need to expose that ring slot to seat the snap ring. There's no way to get a hydraulic press to seat it. I'm completely stuck on this one. I thought she'd go back together like butta. Any and all advice welcome.
Thanks!!
Pics...
Thanks!!
