1 - 11 of 11 Posts
it has 3 sets of wires going to it and its not the idle screw I was driving and it was running good then when i came to a light it wouldnt idle down and i miss typed its a early 86 720 the late 86 is the hard body its 2wd 5 speed
Software Developer
Hi Idle is usually the Air Flow Meter (EF & EC-150) or the Idle Switch (EF & EC-174).
Right-Click the link below, select Save As, and save it to your My Documents folder:
d21_truck_1989.pdf
It is for the 1989, but it should be identical to your 1986.
The ENGINE FUEL & EMISSION CONTROL SYSTEM (EF&EC) is what you need to turn to.
You should start by reading the DIAGNOSTIC PROCEDURE (EF & EC-41) then attempt the SELF-DIAGNOSIS (EF &EC-71).
If you flip through those sections, you will see that #11 on EF & EC-45 is about Abnormal idling - high idle (after warm-up).
There is a big checklist of simple things to look for.
1 - 11 of 11 Posts
