1 - 12 of 12 Posts
Discussion Starter · #2 ·
its gonna go on a gutted plenum, and i havent found much on plenum spacers... anyone else?
other mods for this car would be a t3/4 runnin 10-12 boost, 420cc injectors, so theres gonna be fuel to match the air... i hope.
You can make the 60mm work. take the 60mm gasket and scribe the opening on your plenium and use a dremel tool to match the openings.
· Z31 know-it-all
ok well how about this....
eBay Motors: Infiniti Q45 90mm Throttle Body Nissan SR20DET KA24DE (item 370150196273 end time Feb-01-09 19:30:00 PST)
it states that it will work for a 240, and if a 240 TB will work for a z31, .........
see where im going with this.....
if this would work, what other mods are necessary?
Where in the hell is your common sense? We already said the 70mm throttle body isn't going to work on the Z31's VG30 motor. What could possibly make you think that a 90mm (20mm bigger) throttle body is going to be effective?
A 60mm t/b installed on a stock unported inlet doesnt hit any lips, there is plenty of clearance for the 60mm t/b blade to pivot to full horizontal open on a unported intake...but the intake should be port matched and is very easy to do with a dremel tool...get a 60mm gasket and trace the shape and then port away the soft aluminum...half hour or less!!
It makes an improvement if you match the manifold inlet to it, just slapping a 60mm throttle won't do crap.
1 - 12 of 12 Posts
