1 - 16 of 16 Posts
Your electrical friend
It doesn't happen on the GA16DE maunal trannys as fat as I know, just on Sr20DE trannies. It pops out of 5th gear easily when you're driving. Nissan blames it on a bent shift fork, caused by people resting their hand on the shifter while driving in fifth gear. I don't know of any specific mileage when it starts. I can't remember what it costs to have fixed either, but it's not cheap at all.
bitter old man
For SE-R and G20 information, start at SE-R.NET, then come here and SR20DEFORUMS.
SE-R.NET 5th-gear pop-out article
Applies only to 1991-1993 five speed transmissions attached to SR20DE. Nissan claimed bent shift forks from drivers resting their arm on shifter. That's a bunch of shiite. For 1994, Nissan redesigned certain fifth-gear parts in recognition of the problem but wouldn't perform a recall or acknowlege any design fault. By now, most early 5-speeds have been rebuilt or replaced due to this "feature".
I got a 91 se-r that came into the shop yesterday with 5th gear popout. On this one the shaft bearings were wore and allowed slop in the meshing of the 2 5th gears causing it to pop out of gear. It needed 1 of the 5th gears and all 6 bearings for wear, an axle seal, shift shaft seal, and leaking backup seal. The estimate was like $1800. The customer ended up getting a new trans. I'll be putting it in tomorrow. Oh, guess what? I now have me a spare trans. whhoooo hhooooo!
I had 5th gear pop out on my 93 E (B13) and it sucks. At first it would pop out from time to time them it got realy bad where it would not stay in 5th. So i drove around for a while holding it in 5th when i was on the free way. Then i got tired of it so i took it to AAMCO and it costed me about 1989.00 It was still cheaper than a new trany from Nissan. I highly recomend that if you have this problum then get it fixed right away and dont wate it wont go away.
____________________
www.go.nissanpower.com
It can happen to 94's too. It did on mine at about 135k. I just put in a new tranny from nissan But i damn shure didn't pay 1800 for it;) . It pay's to know the right people.
B13 Owner since 90
A new tranny from Nissan w/ the upgraded internals cost me around $1800 from Nissan back in 1997.
I do not use 5th gear until i hit 55mph in normal driving which is rare on city streets, basically 5th is just for the freeway.
:D
Tevs
Nissan Wizard
Re: thanks
92sentrase said:
thatwas the first iveheard of that. but i shouldent haveany problems with my ga16 right.
I've had 5th gear popout on my 92 se...It was a $800.00 fix for me..I posted it on b15sentra forums last year..You'd be surprised how many non se-r's have or had 5th gear popout.
Just don't use those part numbers though. Those are for the SR20 tranny. I'm sure they can get the same parts for the GA16 tranny though.
  • Like
Reactions: Billot
I have a 1.6 16 valve 2005 Almera that keeps on popping out of 5th i have replaced the complete 5th with syncro's and selector hub 3 times already but every time after a few months it starts to do it again can anyone perhaps give some advise i am from South Africa
1 - 16 of 16 Posts
