1) need clearances for mainshaft and input shaft..
...critical clearances seem to be between rear bearings and rest of gears....it's set with selective-fit spacers & snaprings.....
..could us other clearances too....
2) would appreciate teardown/setup "pitfalls" advice...only have pics in Haynes book, and factory manual is way too expensive....
3) problem is noisy gears, possibly caused by loose/worn bearings..."roars" in all gears but is louder in 4th & 5th...so think it's too much clearance in rear brgs, letting gears separate...(sounds like old truck trans w/straight-cut gears!)..
....could use insight into what typically causes gear noise (roar)...because i don't expect to find anything obvious (no 5th popout)..
...TIA...lou
..PS: it's *not* throwout brg, ring&pinion, or CV-joints..
