1 - 9 of 9 Posts
What lubricant should I use in a 5 speed manual from a '93 Sentra XE? I assume gear oil, but is there any specific brand, weight, synthetic, etc... I should be using? What is the recommended fill procedure? I searched, but didn't find anything that was much help.
Thanks.
i used Royal Purple GL4 80-90w but you can run any GL4 gear lube and it takes 3 quarts to fill up a 5-speed 1.6 gear box. there is a fill hole just under the transmission mount. some times it will not come loose, you can fill it through the speedo cable hole also.
if i dont like the results of the Royal Purple, then i will try the Redline
Just under the tranny mount? Speedo cable hole? Are these places accessable without takiing the tranny out? Is there a write up on this?
uhh, can someone help about a write up or info about how to fill the tranny?
1 - 9 of 9 Posts
