I'm looking to get new front rotors. According to what I see on the net, the 4x4 vs. 4x2 front rotor are different. Is this really true? Are the 4x4 ones larger? Can someone shed some light on this.... Or at least you 4x4 guys measure the diameter of your front rotors for me? Thanks!
Yes 4x4 and 4x2 are different in sizes. You will need to get a rotor that is 260mm to fit your truck.
yes all Nissan truck bolt patterns are the same from the 4cyl to the 6 cyl to the 8 cyl (6 bolt), the other difference between the brakes are the calipers for the HD, 4x4 and 6cly are 2 piston calipers where as the regular cab 4cyl HB 4x2 are Mustang Gt sized 10" rotors with single piston calipers!
Good info, thanks... So now i'm thinking, can I fit the 4x4 brakes on my truck using my spindles? Do all I need are the rotors and calipers? Thanks
