Status
Not open for further replies.
In Ur Threadz - Deleting!
4th Gen Info
How-To’s...Basic information...and Forums
Maxima Modifications...A complete listing of mods available for the 4th gen Maxima including a description.
Chilton’s website...95-98 models only.
Maxima.Org forums...One of the most comprehensive and useful Maxima sites on the web.
AE Headlight instructions for your 4th gen.
VBX Maxima - Maintenance instructions for your Maxima. Very comprehensive...Check Engine Light
Motorvate DIY Mod Site...One of the best.
MaximaDriver.com…website catering to all Maximas with mod-info and forums.
Maxima Stereo/Amplifier Removal…Also has information for removing a defective antenna.
Maxima FAQ...answers to many frequently asked questions.
VQPower DIY Listing...Helpful site for Doing-It-Yourself.
Maxmods.org...Very comprehensive website with information about all types of mods available. Great information here.
I hope this helps some of you out...Newbie or Not.
Discussion Starter #2
Some more helpful links from another member...
Terran said:
Ok here goes:
oil and filter : http://www.motorvate.ca/mvp.php/511
Coolant : http://www.motorvate.ca/mvp.php/502, or this other method which I tried to explain on another forum, but you can find a better explanation at maxima.org once it is back up http://forums.max-world.org/index.php?showtopic=3469
Fuel filter : http://vbxmaxima.8m.com/fuelfilter.html
Air filter : You should be able to figure this out, but I'll explain it if you need it
Spark plugs : http://www.vqpower.com/v2/modules.php?name=Content&pa=showpage&pid=33, http://vbxmaxima.8m.com/sparkplug.html (I believe this sites cold plug description is faulty..they are used in boosted applications). If you do the plugs yourself and don't mind changing them more often (30k rather than 60k), then you will save big bucks (<$2/plug vs around $10/plug) by getting NGK coppers (Ask for NGK bkr5e-11 at local autoparts stores or if all else fails, the dealer).
PCV valve: I'm not sure of a writeup on this except on the org, and I'm not sure I can describe it...it won't hurt to just wait 'til the org is back up.
Clean TB: http://www.motorvate.ca/mvp.php/517
I also remembered some other things. You may want to do tranny fluid, but I need to know what kind of tranny you have first. You may also want to check your ECU for codes (http://vbxmaxima.8m.com/ecu.html), because the knock sensor (code 0304) commonly goes bad on these cars which will seriously effect gas mileage and performance, but it will not set off the check engine light.
Status
