H
heavyd
·Guest
I hit 250 K about a week ago, and she still flies, with 35 mpg.
Slows a little with the A/C on but still keeps going.
BUT, have a problem. Prior to changing timing components a month ago chain, gears, and oil pump, she never used any oil. When I would change the oil it never leaked or burned a drop. Now I am using a quart every 100 miles.
I have heard that the valve advance VVT?? or somthing like that solenoid could be causing the oil to pass the intake valves??
I have Checked: PCV, Air cleaner,Plugs,leaks,radiator,exaust pipe, All are ok no problems.
Can this solenoid be tested??
