240sx 1992 starting promblem, electric dash promblem, windows promblem HELP EXPERTS
815 Views 7 Replies 4 Participants Last post by  bret240sx
ok heres my storie... i drove to cornwall, went to get my hair cut, then got into the car, start the car then it droped, start it again then it droped again start the car again then it worked :wtf ... then got back home, went to get my budies. then went to esso , put 5$ of gas then BAMM.. the car does not start anymore :wtf :Werd ... the dash sudenly got no electric
(no digi meter) and the windows sudenly got freezed (could not bring it back up anymore). we check it out a bit, we tried to see if we can spark it from the coil.. it did not spark . i check all the fuse and all are O.K. The batery is new. all other electric is working fine in the car ... maybe i thinks some wire are dirty.. there is alot of grease in the hood so maybe..
hopefully i would be gratefull if someone commented my response
thanks to the ones that help me
1 - 8 of 8 Posts
If nothings working check to see if the battery still has a good charge. you new one might be dead if the alternators shot. If the battery is low hook up a charger to it and if it does not start and nothing is working I would swap another ecu
^^^^^exactly what he said. your battery is more than likely dead. get it charged then go get your altinator tested.
my battery is new i dont think it that ... i dont have any spark from coil .. il check the battery again and charge it to see
thanks for the replies
Without starting the car, turn on the headlights. If they are very dim or don't light up at all, then your battery is run down.
nope nothing . ive boost charged the battery from another car and i still dont see sparks.. my radio is working my headlight are great and my starter is great..
could it be the ignition coil?
again thanks for the help :)
Check the fuses in the relay box next to the battery. If they're OK, then check the grounds.
the relay is a black box located beside the battery on the right fender?
1 - 8 of 8 Posts
