thanks for the update .... "the problem is almost totally limited to areas with temperatures below freezing" it seems there are some buyers living in hot region too, if I recall correctly the previous postsI can't say anything more at this time, but I can disclose that Engineering has found the source of the problem and there are parts being manufactured as we speak. They'll be issuing a service bulletin as soon as the parts chain catches up. I'm told the problem is a materials issue in the PCV system related to winter fuel (porous rubber would be my educated guess), and that the problem is almost totally limited to areas with temperatures below freezing. The fix is on the way.
