I did the '22 1.5T 3cyl oil change at 3,000 miles. It is different from my '21 Rogue 2.5 also done at 3,000 miles
Both '21 and 22 require removing the belly pan. Two 10mm bolts and 12-15 plastic push pins. Chrysler had a better idea with a flip down access panel on my '17 Pacifica.
The 1.5 used oil was the thinnest oil I've ever seen. It flowed like green/brown water and reeked of gasoline. I've had plenty of other cars with 0W20 oil and none have been like water on an oil change. It is definitely the thinnest and probably the nastiest looking and smelling oil in my experience and only after 3K miles.
I am stupefied that Nissan calls for a 10,000 mile oil change, a tiny filter fit for a lawnmower, and NO requirement for synthetic oil on a turbo. What's up with that Nissan? I doubt this engine will run 200-300K like a Toyota or Honda.
I plan to change mine every 5K with Pennzoil Platinum full synthetic. I will go longer on the non turbo 2.5 but probably not 10K
While it smelled like gas, I think the dilution is minimal because it was never above the full mark on the dipstick unlike the early 1.5T Honda engines that had major dilution and oil way above the full mark on the dipstick because gas dumped into the oil. I am told that Honda fixed that problem.
The '22 has a plastic waffle texture oil pan (a first in the whole of my life) with drain bolt paint marked to properly torque with the paint mark on the metal base at the plastic pan. The '21 2.5 has a conventional steel pan.
The crush washer is a true dual layer "crush washer" unlike any I have seen in over 40 years of changing oil. $1.00 at the dealer.
The oil filter for both the 1.5 and 2.5 is even smaller than the tiny Honda filters and there's room enough for a larger filter from the Nissan truck or the Honda XG7317. I don't know if that voids the warranty??
If you plan to keep the 1.5 for a long time, change early and often. I haven't decided which I'll trade on my Silverado EV. The only advantage of the 1.5 is MUCH better MPG. 28.6 vs 22.8 over 3,000 miles.
