I'm at my wit's end with this car. I have had it in and out of the dealership several times, but they have so far been unable to recreate my issue. I feel like I'm going insane.
The car is a 2018 model that I bought in 2018 with 10k miles on it. It currently has 73k miles and has had all of the regular recommended maintenance. No other mechanical issues up to this point.
The problem is that sometimes when I go to start it (via push button/keyless), it runs for a few seconds like it's not firing all cylinders (engine stumbling, car feels like it's rocking side to side, no dash lights except for sometimes the battery light flashes). The car will usually start after 5 seconds or so, but sometimes it just dies again. When it won't start by itself, giving it a little gas gets it going. Once the car is running, everything appears to function completely normally. This only happens after it has been sitting for at least a few hours. I have never had it reoccur after starting successfully. The problem first started about 8 months ago but it was very infrequent to begin with. At this point it's happening several times per week (yet the dealership can't get it to happen even after keeping it a full week).
Any suggestions for where to look next would be much appreciated. The dealership has said they're willing to keep trying, but they're out of ideas at this point.
- The battery is new and the alternator is good
- the oil has been changed several times since this began, no effect
- the dealership suggested that it could be vapor lock due to being parked on the driveway at an incline, which I thought was certainly possible, but it has happened recently on level ground, too, so I don't think it's that.
- the check engine light came in at one point for a few days, but then went off again by itself. The dealership said that the code should still be present, but when they checked they said there were no error codes stored at all, which is odd. Wondering if there's an issue with the ecu??
