I have fault codes showing on my 2017 Rogue Sport. P0546 and P2018 (Exhaust gas temperature sensor). I would like to make this repair myself but I am having trouble finding where the actual sensor is to see if it's just a loose connector, a broken wire or if I need to replace the whole sensor.
Can anyone help with this? TIA
Sup Mod keeping the peace
The P0546 indicates that there is a malfunction related to the exhaust gas temperature sensor circuit. It should be located in front of the CAT.
The P2018 fault code is caused by a malfunction of the Intake manifold runner control valve position sensor/curcuit. The sensor is connected to the front end of the valve shaft; the Intake manifold runner control valve is integrated to intake manifold. It should be located at the front of the engine.
Discussion Starter #3
Thanks. It looks like I typo-ed. I should have said P2081, not P2018.
Discussion Starter #4
How difficult should replacing the sensor be? Is it something I should be able to do easily in my driveway or do I have to dismantle half the car to get to it?
You would have to jack up the front of the car to access the sensor. It should be somewhere between the exhaust manifold and the CAT.
