I'll give Nissan a call tomorrow, yes will definitely keep you posted
Strange that you have the same fault. I had the RAC out, they checked everything. Changed the battery, checked all fuses with no success. There must be something going on with this if it has the same fault. Do you have rust near your battery, the garage has reported back that there is more rust is this area than normal, its still like a new car!!I'll give Nissan a call tomorrow, yes will definitely keep you posted
My car has not been used due to COVID too, probably only 2000miles in a year. My battery also had yellow stuff around the points, RAC guy said this was okay. I also though my battery was failing, this was not the case. Hopefully yours is resolved just with a new battery, if you try Nissan recovery they will send out RAC. Worth ruling out these things first.I had a look around and couldnt see any rust anywhere in the engine bay. I will have another look around in the light, there is some yellowish stuff over the terminals - havent noticed that before. I was thinking maybe the battery could be failing seeing as its 4/5 years old and the car has been used a lot less due to Corona.
I'm going to call Nissan UK on Monday for an update on my Xtrail. If your fault is the same as mine this major fault may be happening to other 2016 models. It may be a software or electrical fault that Nissan will need to take responsibility for. I will keep you updated.Got my car towed away today. Ofcourse, to make life complicated the wheels were turned and handbrake was on so the car had to be dragged onto the lorry.
They also fitted a new BCM to my car and this did not fix the problem, my car is still in the garage and has been around 7 weeks now!!!So, they have fitted the new BCM and the car is still dead. The Nissan dealer is back on the phone with Nissan Technical
Is there any way that I can call you without sharing contact numbers on here?They also fitted a new BCM to my car and this did not fix the problem, my car is still in the garage and has been around 7 weeks now!!!
You can click on their names and choose to send a private message.Is there any way that I can call you without sharing contact numbers on here?
Any Update? I sent you a private message to discuss in more detail.My car is being worked on today. It’s a 2016 Xtrail, tekna, 2wd, diesel auto. Let me know what Nissan say.
Any update on your xtrail ?Any Update? I sent you a private message to discuss in more detail.
