Have a 2016 Frontier 4x4 Auto with tow package. Question is with abt 1800 lbs is it good idea to tow in 4th gear not OD. traveling abt 2000 miles .....Thanks to all that reply....Virg49
Virg,
1st Read and Study the Owner's Manual on Towing. Maximum Frontal Area, Tongue Weight, etc. Remember You are Towing the Weight of the Trailer + the Load Weight.
A lot of Variable Factor's come into play when Towing; Trailer Frontal Area, Hill's, Head Wind, Cross Wind, etc. Trailer type make's a Huge Difference whether it is an Open utility Trailer or an Enclosed Trailer With a lot of Frontal Area. Wind Resistance is a Huge Factor when Towing.
Be sure to follow the Break in Advice in the Owner's Manual; For My '13 Towing, it is 50mph maximum for the 1st 500 mile's, and there is a Break-in for the 1st 1200 mile's as well. If in doubt, or to Play It Safe, disingage the Over Drive to save your Transmission and Engine. After the Break-in, with the OV Disingaged try not to exceed 65mph. If you want your Truck to have long Durability,, Don't be in a Hurry.
My Best Advice is to Read and Study the Owner's Manual,, and Talk with Your Nissan Master Tech/ Service Manager to get their Perspective and Advice.
Discussion Starter #3
ok thanks, have aluminum open trailer 450lbs with 1250 lb motorcycle. Truck has V6. Will try to tow with OD off...Got 3000miles on truck so maybe good to shut OD off ...thanks agn...Virg49
