Hello from Las Vegas
Helping a friend with a 2013 Pathfinder 3.5 that simply cannot make any power in gear. Holding pedal to the floor it would be a stretch to make 20 MPH. At idle in park it surges a lot but doesn't stall. Scanned for codes and found P0300 for random misfire and P0101 for MAF sensor/circuit. Owner claims the sensor is new. If in park and idling the MAF is disconnected, the idle smooths out and no more surging. That leads me to believe the circuit is intact. Also, if I clear the code with scanner at idle in park, it smooths out with MAF sensor connected. It will stay smooth until put into gear and a load on engine. As I mentioned above. WOT throttle yields almost a total cutoff from engine, however if I lightly apply throttle, I can accelerate more. But to be clear, partial throttle request still has reduced engine output. As far as the misfire goes, I cannot feel/hear/experience it at all. When in neutral, the engine will tach up. I am not a Nissan guy so cannot attest to whether it tachs up normally or seems to be reduced power as well. I don't feel this is transmission related even though neutral seems to produce more RPM, as it still surges in neutral or park at idle. Seems to be "load" related.
I rebuild GM 2.4 direct injection engines here in Las Vegas so I am not afraid to repair this vehicle, but was hoping for some hints on how to proceed. My scanner is a Bosch tablet that is fully updated and can program, however the Nissan computer has several different "routes" to info vs the GM libraries I am used to. For example I have not found the data stream that looks at a misfire graph by cylinder. I was hoping to take that random misfire code and narrow it down. Anyway any advice is helpful. Or ideas on where to diagnose next or what other info you Nissan peeps need to assist me.
2013 Pathfinder S
84,500 miles on odometer, owner says engine was replaced couple years ago. Above issue is a new development.
