Hi. New to this forum and have searched here and google but can’t seem to find anyone that has
Info on the (what appears to be) a leaking oil pressure sensor.
The sensor appears to screw into a long 19mm banjo nut with a reddish gasket.
It’s located underneath on the passenger side near the AC compressor.
Can’t seem to find any pictures or YouTube videos. It’s seeping oil where the nut meets the block.
I was able to tighten the nut 1/2 turn or so with the wire harness attached to see if maybe it just loosened up
Over the years or if maybe there’s an gasket or Oring that needs replacing?
