1 - 10 of 10 Posts
Hi Folks,
I had my 5sp manual transmission take a dive and am going to have it rebuilt. My car is a 98 200sx-ser ..... the transmission was swapped out for a 96 before I purchased the car..... since the 96 has the LSD.
1) Is there anything than can be done to the 96' tranny during the rebuild process to beef it up at a reasonable cost.
2) Is there a higher 5th gear available ..... so that cruising at 65 mph is done at a lower RPM...
Current modificatons to increase power: cold air induction, lighter flywheel, header, full 2 1/4" exhaust... I hope to eventually get to 200fl/lb torque, 225-250 hp..... and would like to rebuilt the tranny for that now while I got it out of the car.... Any info would be appreciated.... Thanx
Stack
Banned
did you know you can swap a b15 tranny in?
Banned
Stackdaddy said:
Are you referring to the site for Mossy performance??.... If so, I will check it
out instead of persuing it here....... Thanx
....noooooooot mossy, did you click the link?
There are two things which strengthen the trans:
Cryo treating the gears (especially 3-rd)
http://www.sr20forum.com/showthread.php?t=7284
http://www.sr20forum.com/showthread.php?t=47256
Welding the case
http://www.sr20forum.com/showthread.php?t=55334
A more expensive option is a PAR gearset which is almost bulletproof.
http://www.sr20forum.com/showthread.php?t=76677
Lew
I already knew about the Cryo treatment, welding the case and the $3000 PAR gearset ....... from the archives that I found. I was wondering if there was anything else..... say.... a rebuild kit from a place a little more local than Australia and somewhere around $1K or less for the parts....
In addition is there a 5th gear available with a higher ratio?? say maybe from the G20 or some other manufacturer that will fit the 96'.... just a thought....
Stack..
There are 5 B15 transmissions:
Automatic
RE4F03B Final Drive: 3.827:1
Re4F04B Final Drive: 4.087
Manual
RS5F70A Final Drive: 4.176 5-th: 0.756
RS5F51A Final Drive: 4.133 5-th: 0.772
RS6F51H Final Drive: 4.428
I don't know if any of these are interchangable, but I would guess that the final drives are the most likely to be.
Lew
[Did I waste my time again getting information he already knew?]
Discussion Starter · #10 ·
Thanx Lew.... That hit the nail on the head....
And the earlier post that directed me to the sr20forum.com..... (That I could'nt see with my one good eye) .... I thank you..... There are a couple of lengthy threads on there ... w/pics and additional info on the B15 and the swap from a B13 or B14...... you da Man!!!...... Give us old farts a little time and we will eventually get there.... just don't ask us how we got there... afterwards.....Thanx
Stack-D
1 - 10 of 10 Posts
