hey guys,
At the local junkyard there are more than several 95-99 200sx's and a couple have the full rear disc brake kits, now with my sentra I HATE rear drums and have been curious about an Se-R rear conversion, but is it possible to convert the rear end with disc brakes from a 200sx? Just wondering it seems possible but I'm not sure if the rear hubs are the same size or not...Good Idea?
2018 Nissan Pathfinder SL
Yes you can
Two ways to do this (for B14)
1) swap the entire axle assembly brake lines and E brakes cables
2) use "fast brakes" adapters with includes brake lines. PLUS your calipers, disc and Ebrake cables from a Disc brake car (SE-R etc)
· Cone Dodger
i did the whole rear axle swap. just make sure that you get the right park brake cables because you'll really, really need them if you have a manual.
also check the master cylinder you have on right now, you might have to change that when you do swap.
