I am sort of new here, I tried searching for this and couldn't find anything.
I just bought a 98 200sx with almost 60k on it. I just had the clutch replaced a couple days ago. With the new clutch it seems to want to "catch" with the pedal too close to the floor. In other words, I really have to push hard and all the way down to go into reverse, AND let the rpms drop. Anything else and it grinds like hell. Sometimes it grinds in 2nd (which I gather is 'common' in these cars)
My clutch cable is adjusted all the way, there are no more threads left the adjust to. For now, I have installed a rubber 'shim' that I had in my basement (amongst the junk) and it has helped, but I think I need a new cable.
So, is it common for clutch cables to stretch that much after 60k miles? I am not sure if the cable is stretched or if the guy that changed my clutch did it incorrectly. There isn't anything he could do that would cause that is there? Is it possible that my flywheel is ground down too much or something?
My main concern is that the mechanic fuxored up my clutch or something, however it doesn't grind and I don't get clutch chatter.
How difficult is it to replace the clutch cable?
Is there an adjustment on the pedal-side? (I didn't see one)
Thanks!
Thanks!
