Hi All,
Last night I went to leave my sister's house and the car battery was dead. I was at her house for about 5 hours. When I went back to the car I was hearing relays clicking on and off. I disconnected the battery and put it back on and it stopped. This morning I jumped the car and after a few minutes it started. I have a Topdon AB101 and after running the car for about 30 minutes I ran a load test of 640CCA (Interstate battery from Costco) and it indicates to replace it.
I just don't know how the battery would just die all of a sudden like that. I verified that I didn't have any indoor lights lights on and if I had the outside lights on it would have beeped when I was exiting.
I then put a load on the alternator to see what the current was generated and with the A/C, outdoor and indoor lights radio, rear defrost I was only getting around 12.78V. That seems low correct? I also ran the load test and it was kind of confusing but I was running the RMPs at 4000 after I pressed ok (which from what I read in the manual you run it at 2500 RPMs for 5 seconds then press ok). I will re-run this test again to verify. I assume I need to replace the battery first correct before going for an alternator replacement? Also the alternator is making a moaning sound under load, when I turn off the lights and A/C it goes off. I have verified that the fans are not the culprit as they aren't running once the A/C is off.
I don't remember when I put this Autozone one on but should I chance brining it to them to verify the test before pulling it our and having them test it or does my initial testing seem to indicate the alternator is also failing? Any help would be appreciated.
Thanks
Thanks
