Hello, I have a few novice questions. I know a fair share about cars but clearly I am not all knowing. I have owned many cars in the past and it was always easy to find oil specs and everything for my cars. I am having some difficulty here.
What kind of oil should I be using? I usually but synthetic in my engines, my Ford Taurus oil change was usually 40 bucks no big deal. I recently took my Nissan Sentra SE-R to a Nissan Dealership and they wanted to charge me 79.99 for synthetic oil. wtf? I could change the oil myself (and at 79.99 I will start doing that) but I would rather just pay 40 and have it done to be honest. I did that with my ford and I ended up putting 183k miles on my Taurus before the body started to rust out (Still ran great)
Does my engine not take synthetic oil as OEM? What gives? I know dino oil is ok for about 1k miles if the engine needs synthetic so I am just checking
Also if I were to install a turbocharger on my car would I damage the engine? Would I need to tune it? Should I tune it? What would the cost be?
Any advice and suggestions are MUCH appreciated!
Sup Mod keeping the peace
The recommended motor oil to use, as indicated in the FSM, is a 5W-30. You can use a fully synthetic oil with no problem. Mobil-1 fully synthetic is a very good oil. I've been using it for years in my Nissan's. Since synthetic doesn't break down readily as does dino, I change the synthetic oil every 12,000 mi and change the oil filter every 3,000 mi.
