2008 Nissan Pathfinder Transmission Malfunction
Description of the problem:
Important Note: This problem must be identified when the vehicle is on a sloped road, as the problem is not as noticeable on a level street where there is no downward gravitational pull.
1. Problem: Delay when shifting from Reverse to Drive on upward slope
When the vehicle is on a street that is sloped upward, and after backing up I shift from Reverse to Drive, the vehicle will continue to roll backward (downhill) as if it is in Neutral for a few moments before it changes to Drive.
2. Problem: Delay when shifting from Drive to Reverse on downward Slope
When the vehicle is on a street that is sloped downward, and after driving forward I shift from Drive to Reverse, the vehicle will continue to roll forward (downhill) as if it is in Neutral for a few moments before it changes to Reverse.
3. Problem: Delay when shifting from Drive to Reverse or Reverse to Drive
When the vehicle is on a street that is level and not sloped, and I shift from Drive to Reverse or Reverse to Drive, the vehicle may not roll due to the lack of a slope, but it will have a delay as if it is in Neutral for a few moments before it changes to Reverse or to Drive.
The mechanic at the dealership said that this issue is 100% normal and that his personal Pathfinder does the same thing. He says it was okay until now because it was not yet broken in.
Is it true that this is typical or is it in fact a transmission problem?
(note that once the gear is engaged there is no rollback, it is only in the first few moments after switching from Reverse to Drive or vice versa.)
