1 - 7 of 7 Posts
Hello guys! I just recently received a P0128 error code on my 2007 Nissan Altima 2.5S and was wondering how many coolant thermostats are there? Nissan tells me, there is one but I have seen schematics showing there is two. I recently had my car serviced at a Nissan dealership and they have replaced one thermostat and re-filled coolant. However, a week and half later, the SES light came back and code P0128 was again detected.
the thermostat is on the side of the engine, there is what they call a "water control valve" (which looks like a thermostat) on the back of the engine... if that helps
Discussion Starter #3
Thanks Speedo. Would that need be replaced as well for a P0128 considering that it's for the water pump? I would imagine the primary would be the coolant thermostat.
Sup Mod keeping the peace
There are two thermostats. The main one feeds the radiator. The second one is called a water control valve which feeds several accessories such as the heater and oil cooler; it's purpose is quicker warmup for the accessories. If it's stuck closed, it could possibly cause overheating.
Misdiagnoses? If P0128 was what the repair was intended to fix then return to dealer for a redo. ECT sensor maybe miscalibrated.
Discussion Starter #7
@rogoman- Thank you. Had no driveability or overheating issues since the engine light and code came up. But that second sensor by water control valve maybe a culprit The only thing that was changed by me was the Coolant sensor @cj1 it was an aftermarket part. A mis-calibration is something for Nissan to check as well. Thank you both!
1 - 7 of 7 Posts
