Hi,
Does anyone know of the 2005 SE comes standard with tire pressure monitoring system? I just bought a used 2005 se but dont know if it has the tire pressure monitoring system or not, is there a way I can check to see if it does? Thanks
I believe it is standard on all cars from 2003+ It is definitely on your vehicle. there will be a yellow tire symbol with an explanation point (!) on the dash when you start the car.
It will light up when a tire reaches less than 28psi or if the system malfunctions/low battery in sensor...
