Does anyone know if the CD changer that comes with the Rockford Fosgate audio system in the 2005 Frontier is the same as the connector in the standard single-CD unit? In other words, are they interchangeable?
The base-level sound system doesn't have a connector for the CD changer, if that's what you're asking. It just has the two standard Nissan harness plugs.msubullyfan said:Does anyone know if the CD changer that comes with the Rockford Fosgate audio system in the 2005 Frontier is the same as the connector in the standard single-CD unit? In other words, are they interchangeable?
Have you tried disconnecting the battery for a while. It might clear the memory.SDBryan said:Be carefull when hooking it up...
PS - DO NOT REMOVE THE FUNNY LOOKING PLUG ON THE BACKSIDE OF THE CENTER DASH!!!
It is connected to the AIRBAGS and will make your airbag light flash if you unplug it!!!!
I have to go to the dealership to get it to turn off!!!
DUDE - YOU ROCK!!!! THANKS!!!msubullyfan said:Here's the process to reset the air bag light (copied from somewhere else on the forum)... I tried it and it works.
Hey msubullyfan, for sake of future reference, are they interchangeable? What all have you found out since then? Zmsubullyfan said:Does anyone know if the CD changer that comes with the Rockford Fosgate audio system in the 2005 Frontier is the same as the connector in the standard single-CD unit? In other words, are they interchangeable?
If you have the airbag light, it will show steady for a few seconds (the manual says 7 secs) after you turn the key from off to on (but not start) and then start to flash. Here is how to reset it:
1. Turn the key from off to on.
2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly.
3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)
4. Repeat steps 1-3 two more times until you have done the cycle three times.
5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.
6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
If it does not work the first time, just repeat the steps again.
Just performed this trick on my 2006 Pathfinder SE, worked perfectly. Just had to make sure that when that airbag light goes off you IMMEDIATELY turn the key off. I didn't read the instructions that close the first time but worked 2nd time around. Bravo!msubullyfan said:Here's the process to reset the air bag light (copied from somewhere else on the forum)... I tried it and it works.
I found this post via google. Sorry to comment on an old thread. But this worked great, and probably saved me an expensive trip to the dealership. I really appreciate it.Here's the process to reset the air bag light (copied from somewhere else on the forum)... I tried it and it works....
