goatty9 said:
I recently got a 1441 code on a 2001 Sentra. What does it mean?
I assume a FSM is a Service Manual? Where is a good and cheap place to get one?
I'm in Canada
Here is the error code list of items it could be.
P1441--EVAP system has a very small leak.
EVAP system does not operate properly.
Incorrect fuel tank vacuum relief valve.
Incorrect fuel filler cap used.
Fuel filler cap remains open or fails to close
Foreign matter caught in fuel filler cap.
Leak is in line between intake manifold and
EVAP canister purge volume control solenoid
valve.
Foreign matter caught in EVAP canister vent
control valve.
EVAP canister or fuel tank leaks.
EVAP purge line (Pipe and rubber tube) leaks.
EVAP purge line rubber tube bent.
Blocked or bent rubber tube to EVAP control system
pressure sensor.
Loose or disconnected rubber tube.
EVAP canister vent control valve and the circuit.
EVAP canister purge volume control valve and
the circuit
valve
Absolute pressure sensor
O-ring of EVAP canister vent control valve is
missing or damaged.
Water separator
EVAP canister saturated with water
EVAP control system pressure sensor
Refueling control valve
ORVR system leaks
Fuel level sensor and the circuit
Hope this, Bill
