I have a 2002 Frontier Crew Cab 2WD with Automatic Transmission. It currently has 52,000 miles on the odometer. I've had very few problems except for the leaking rear brake light and a horn that does not blow properly. I repaired the brake light myself by applying silicone caulk to the gasket. It never leaked again.
A week ago I took my truck to the dealership for an automatic transmission service and a re-call repair. The re-call repair had something to do with the fuel system. They claim that the technicians had to remove the back seat for this repair. Everything seemed fine but within 24 hours my fuel gauge became inaccurate. It would go from showing full to empty in a matter of minutes. The fuel light may stay on the entire trip and then go off while the fuel gauge creeps up to 1/4 - 1/2 full on the next startup. After a few days of this the "Service Engine Soon" light came on. The light has remained on and the fuel gauge in still all over the place even when the tank is full.
I have not tested my truck with an OBDII scanner yet.
Has anyone experienced this problem? Could the technician have caused this problem when the fuel system re-call repair was done?
Thanks for your input!
