The stock 17's on the Altima are approximately 24lbs, try to find a wheel that is slightly lighter or at least equivalent to the stock wheel weight. I would get 18" x 8.5" +45mm offset or 18" x 8" with a 40-45mm offset with 245/45/18 tires. There are so many tires out there these days and everyone has a different opinion so it is difficult to suggest any particular model. There are many tires to fit your application, search around and you will find one best suited to your needs and you wallet.dragon_tj said:hey guys i am looking at getting 18's but i dont want to end up losing acceleration should i go with 17's?..if so what offset etc do i need ...and what are the best all around tires now and days?
Shouldn't have any problems at alldragon_tj said:if i get a 45 offset i should be able to run 245 45? i am planning on dropping it atleast an inch
No problem...when I was running with 18's I had 245/45 rubberdragon_tj said:if i get a 45 offset i should be able to run 245 45? i am planning on dropping it atleast an inch
ALTYHOLIC said:No problem...when I was running with 18's I had 245/45 rubber
sitting on a 8" wide rim and a +38 offset. All that WITH Sportlines and
still no rub.
LOL...Mark said:I pwn your 18"s![]()
ALTYHOLIC said:LOL...![]()
I'm talking about the set I got after
I sold you those Mille Miglia's...
Dizamn, I've had so many wheels on that
car I lose count... :crazy:
My current goal is to find some lightweight
17 x 9's with the right offset and run some 255's
on them...
