Hello GUys, am new to this forum. my pathfinder cranks but wont start, the tach meter doesnt move when cranking, no spark on ignition coil 1. the voltage from the ignition coil harness and ignition condenser harness reads between 8 and 9 volts. the battery is brand new and voltage on the battery is 12.7 volts. i sanded and tightened the ground contacts for engine and chassis. what do you think the issue could be?
please i need to get the engine running again.
thanks!
NF Mod/Nissan Master Tech
Usually a bad crank position or cam position sensor will do that. Are there any stored trouble codes in the ECM?
