1 - 18 of 18 Posts
I was told to replace the ECM, the Engine Control Module, to fix an idling issue. Got it from eBay and replaced and fixed it. But to my surprise, AC is acting. Compressor and blower run, but apparently thermostat is not functioning. It blows hot air even I set the Temp at 66! the "Auto" button is not working.
I am afraid to take it to an AC mechanic, as it seems to electronic and thermostat issue. Any advice is highly appreciated.
If it blows cold air at the very bottom setting (60 on most Nissans, I don't know about yours specifically), then chances are you just have a bad temperature sensor. Without pulling out the wiring diagram, most Nissan Auto AC systems have three, an ambient sensor in the grille, an in-car sensor under the dash, and an intake sensor on the AC evap. If any one of them fails, they usually read -20 to -44 degrees. The HVAC thinks you're at the North Pole and stops blowing cold. Pushing the temp to the bottom is sort of an "override" that tells the HVAC to "just blow cold", so that's the tipoff to a failed sensor.
Thanks very much. Something like that I guess, except the lowest in my 2001 Pathfinder is 65. I used to "override" manually setting at 65 to cool and manually adjust fan speed. But now it blows hot air even at 65!. Do I have to replace all sensors? any idea on costs involved in parts and labor? BTW, I have already ordered the AC control module on the dash, from eBay. Will arrive next week. Sharmanp.
Sounds like you had a bad sensor and now something else in the system has gone south, so you need to fix the "no cold" problem first. Is the compressor turning on? If not, you may just be low on refrigerant or have a leak somewhere. Once you get the system to blow cold at 65, then you can troubleshoot the sensors. They're all "balance resistor" setups that produce an analog voltage that changes with temperature, so you're looking for one that's stuck at a high voltage with no movement. The ambient and in-car sensors are generally easy to access and replace. If it's the intake sensor you're probably into a much bigger job, most of them are inside the HVAC box attached to the evap. Fortunately, those rarely fail.
Looks like you nailed the problem. I can dabble by trial and error, I cant do more damage than what it is now. I will try.
Could you possibly point to any youtube videos on this? or keywords I dig up some?
I need some visual before I can pretend to be a doing anything under the hood.
Thanks very much!
Sharman.
The ambient sensor is right up in the grille on the radiator support:
7460
The stuff in the passenger compartment is all accessible by removing covers and the glove box. It turns out the AC Auto Amp is integrated into the display unit, and even the intake sensor is reachable and replaceable without any major surgery. So you should be able to get a voltmeter on all the sensors without too much difficulty. For all 3 sensors, one wire will be ground and the other is signal. You'll want to see voltage on each signal wire change with temperature. Holding a Bic lighter on them for a few seconds should suffice for testing. When you find the one that doesn't move for Mr Bic, that's the culprit. Pretty simple.
7461
PS - To back-probe the voltage with the sensors plugged in, get a safety pin assortment from Walmart or Dollar General. Push the pin underneath the rubber seal on the back of the connector to make contact with the metal pin inside. No expensive tools needed.
Man, you make sound so simple....the graphics from the service manuals are great. Let me tinker a bit and see if this all makes sense to me. Are these from the Nissan 2001 pathfinder service manual?
Thank you! Sharman
Discussion Starter · #10 ·
Thanks.
I recharged gas using A/C Pro ($39) and now the AC is cooling, at 65 (min). Not super cool, however. I could fill more, up to 50psi. Looks like my one or more senses are bad. Blower, all ventilators/door motors are working.
The most likely one to fail is the ambient, the sensor and harness can get whacked by road debris up in the grille. Check that first.
Discussion Starter · #12 ·
I took it to, a local mechanic, nearby, after some checking. Now he broke the whole wood grain dash planel. He promised that he would replace it, and I am not sure he can. I am worried. He is not able to isolate the cooling /sensor problem yet, clearly, he does not know what he is doing....now my SUV is with him for one week, with the front panel all broken up.... any advise? I am searching for the wood grain panel and nothing came up yet on eBay....:(:mad:
7484
7485
That's a chronic problem with the woodgrain plastic on old Pathies, they get severe embrittlement and become impossible to remove without breaking. It's a well-known issue and the guy probably should have known better and warned you, but the breakage per se isn't really his fault. I'm probably the world's most careful tech when it comes to interiors, but I can tell you from rude experience that impossible means impossible. Once they reach a certain degree of embrittlement, there's no removing them in one piece.
I know @smj999smj had the same issue with his old Pathies and it sounded like he had a line on people making plastic-printer replacements. Maybe you can PM him if he doesn't catch this and respond to you here.
Discussion Starter · #14 ·
He assured me that he has qualified people and he will figure it out and fix it. I tried to provide him as much information as possible but repeatedly said he will fix this. clearly, he is not top of things and now he broke the panel without being upfront about this. He is responsible for this breaking of the dash panel, he assured that procured the part already. But now he said he can not diagnose isolate the issue. He has been insincere right from the beginning. He is responsible if he is running a legit business. I am willing to work with him on the cost of the dash panel if he at least fixes the cooling problem.
That sounds like the right approach. I wasn't implying that it wasn't his fault, it's a well-known problem. If he really does know anything about Pathies, he should have warned you before ever touching the dash. Makes me suspect he doesn't know, so I hope he can get your AC fixed without too much screwing around. Crossing my fingers for you!
Discussion Starter · #16 ·
Let's hope so...looks is he is giving up....will know today. A couple of times he told me to get a second opinion....I insisted that he fix that..because if I take the car out...I will own everything, and a broken panel. that is what I am afraid of.
I dunno if you realize it, but the goofy thing is that none of the three sensors require removing those panels for access. The in-car requires dropping the left lower dash, the intake requires removing the glove box, and the ambient is up in the front grille. Makes this whole episode seem sad indeed. Maybe you should have printed the diagram I posted and handed it to him. o_O
1 - 18 of 18 Posts
