I'm trying to program the keyless entry and its not working I did every thing it says, the hazards don't flash I tried it any ways cause on another thread some one said it worked with out them flashing but not for me. Any ideas?
Step 1) Sit in drivers seat, close all doors.
Step 2) Insert key into and remove it from ignition key cylinder more than six times within 10 seconds.
(Hazard warning lamps will then flash twice).
NOTE:
Withdraw key completely from ignition key cylinder each time.
If procedure is performed too fast, system will not enter registration mode.
Step 3) Insert key into ignition key cylinder and turn to ACC position.
Step 4) Push any button on remote controller once. (Hazard warning lamps will then flash twice).
At this time, the oldest ID code is erased and the new ID code is entered.
