Yes, I did search.
No, the holding the foot down on the accel. pedal does not make it start.
Yes, it does flood. I pulled all 4 plugs out and there was a ton of fuel sitting on top of the pistons.
Yes, I did clean the plugs and check for spark. It has nice blue spark on all 4.
I unplugged all the injectors and managed to burn off all the fuel after several times of cranking/cleaning the plugs.
No, it still doesn't start. I plugged the injectors back in and it floods. It won't run. Anyone have a clue as to what is causing it? It is the same thing as the other posts, but no one seemed to have a fix. I got it to do nothing more than stutter and die. ANYONE??
No, I have not checked fuel pressure or temp sensors.
2018 Nissan Pathfinder SL
Did you pull the pump fuse and get it running that way?
Others have put a switch on this.
What Engine do you have? GA16DE? Check your CTS (Coolant Temperature Sensor). If this sensor is busted it will give signal to ECU to feed more fuel to the cylinder. This happened to me once. Or try to unplugged the sensor (your fan will run at this time) then start your engine. It will take some seconds before you start your engine due to some remaining fuel in cylinder. HTH
