I took my 1996 Pathfinder in this morning to get it smog checked. It failed because it was putting out to much NOX and because they couldn't perform all the tests. Last night I got a code for a shift solenoid malfunction so I reset the code knowing it wouldn't pass with a check engine light. (This has been an intermittent problem.) Anyway, I think the NOX problem is due to the timing being out of spec and its being fixed. However, I need to know how many cycles it need to go through before I should take it back for a re-test. Hopefully, the shift solenoid problem won't before I can re-cycle the ECU.
TIA
