I have a 1996 maxima the will not start. Have had cam sensor and anothersensor under front end replaced. Even put a ecu on it and it still will not fire. It Seems to turn over slower than normal. Have put new battery on it. Any suggestions would be greatly appreciated.
· In Ur Threadz - Deleting!
Checked all your grounds?
Last time you had tuneup? (ie. Spark plugs/fuel filter most importantly)
Checked all fuses...including fuel pump?
Have you done tests to make sure you are getting fuel?
Lastly, do you have a check engine light on?
· Back in a Nissan....
Its time to break it down to basics...
Voltage...
Fuel...
Spark....
Does it run even for a second or does it even start at all?
