Hello all.
I have a 220,000 mile 1995 4 cyl/5speed manual trans Pickup truck and im having trouuble with the idle speed. About a month ago, my trucks idle speed ranged between 700-900. But after a 6 hour drive from houston the speed went up to 1500. i changed the O2 sensor and the temp sensor and had no results. Also i adjusted the idle speed screw under the filter but it wnt down to 1200. i also checked the spark plugs and the gas and air filters and still no good results.
Do you have any more ideas on how to fix this??
Thank you
Thank you
