I rebuilt complete timing chain assembly 4 times including installing ratchting timing chain tensioner new fronnt cover new pump then back to old pump but cannot get oil to fill filter. The story goes like this. bought truck drove a year great shape but several little things like missing bolts altenator not mounted properly etc. truck suddenly stopped the timing chin had eaten guides etc. Read up on infamous start up rattle problems in tensioner etc. 1st rebuild started but poured oil out of the t where head meets front cover. 2nd time discovered cover was not ntorguing properly stripped threads on the engine front cover also previous inept mechanic had chicken shited the whole process helicoils not a good answer would not hold properly and line up correctly. 3rd new front cover used hand made gaskets too fix missing head gasket where cut off oil leaks fixed but now pump would not pump 4th attemp packed new pump with grease redid everything still no oil getting to filter. I know the whole assembly is correct could the tubes inside engine be cloged? any ideas?
thanks [email protected] or here.
