Hey whats up? I have run into a problem. My little brother was driving my car the other day, and as he was coming around the corner to our house, my 95 Altima died on him. Well, when we try to start it, you can hear it try to start but it just doesnt seem to want to. Someone suggested putting a new distributor in it. Any suggestions?
check the fuel pump fuese.
Well i finally found out what was wrong with it. When i had tried everything else, i ended up doing a compression test on the engine and found it to be around 30 psi. The manufacturers recommendation was to be around 150 so i put a teaspoon full of oil into each cylinder and raised the compression. Turns out in the end all it was were really bad piston rings.
