I think that's a weep hole or similar overpressure outlet...when it leaks, it's time for a replacement. There is no bleed valve or screw for the MC, when you get a new one it needs to be bench-bled before install, then your brake lines need to be bled as well IIRC. A new MC isn't that expensive, I think mine was $47 or so.
