WHATS THE OIL PRESSURE AT IDLE ON THESES CARS , AT IDLE I ONLY SEE MAYBR 7PSI BUT WHEN I GET ON IT IT JUMPS UP CLOSE TO 60PSI I HAVE 165,000 ON THE CAR. THANKS MIKE
ex-Super *********
You have a GA under your hood? If yo do here are the specs:
At normal operating temp
Idle - 7 to 27 psi
3000 rpm 50 to 64 psi
My car runs close to the same psi as yours, I think your all set. I only have 46k on my GA. I do use synthetic(which may lower my psi readings), but for the milage you have, I wouldnt worry.
