1 - 7 of 7 Posts
Hi,
Is the fuel filter under the drivers side rear wheel near the gas tank replaceable, if so how is it done ?
1993 Nissan gxe 4 dr
1.6 litre
Twin cam - 16 valve
Thanks for your help.
Destroyer of worlds.
you can just remove the gas cap to release the fuel pressure. The removing fuel pump fuse while car's running doesn't work that well...as I found out. :balls:
Discussion Starter #6
1993 Nissan Sentra fuel filter
Thanks for the tip, that will make this a lot easier
Discussion Starter #7
1993 Sentra Fuel Filter
Oldnissanguy said:
Be prepared with some extra fuel hose. Most of the time you will find that they seem to be welded to the filter and have to be cut off. I don't know why.
Thanks- Better to be prepared - I guess eventually the rubber will dry out from the heat etc -
1 - 7 of 7 Posts
