even better the 2nd time
you have to call the nissan dealership and they can refer you to the correct phone number.
its just a number you call and verify some info, and they'll give you a code to put into the Head Unit to get it to work.
Thanks!!
thanks!! I will try that...Where is the head unit?? Is it under the dash or are you refering to the radio numbers??
Discussion Starter · #4 · (Edited)
I called the Nissan Dealership and they said that if the radio does not flash "CODE" that it is a fuse. That there are two fuse boxes under the hood. Do you know where they are located?? :fluffy:
