Going to change my thermostat but i can't find a manual that shows how...I know the KA24 engine has a water temp gauge but need to know any tricks to changing this thermostat
Any advice would be helpfull
robert
Biru O' Kudasai
The thermostat is located in the lower hose neck and replacement is fairly straight forward. If you need more on the replacement procedure, check with your Nissan dealer they may allow you look at the service manual for your car. Also the air bleed in the thermostat should be straight up when installed.
Troy
Biru O' Kudasai
The water pump housing has the thermostat in it. You should remove the water pump as a unit to change the thermostat and inspect the water pump at the same time.
I posted a place to get the service manual in the Stanza section.
Troy
