OK admit I am a dork when it comes to AC units, but how can I tell if my system has R12 in it or 134? A friend told me to look for tags or stickers that say 134 and none can be found. The 2 fittings it has on it are described as this: Each has a cap on it that has threads on the inside. Once you remove the caps then the fitting looks pretty much like a valve stem on any old tubeless tire rim. It too, has threads on the inside of the stem. Like I said it looks like you could use a needle tool and unscrew it just like a tire valve stem.
I have pictures I can send
What else do I look for?
I am thinking it is R12, if so, can I just add to existing with R12 or do I need to evacuate the whole system? The unit works and blows, just not very cold, esp here in Texas now with the 100 degreee days!
